1985 SeaRay 230. chevy 350 . Was running boat and went through some sea weed. About 5-10 minutes later the boat started running sluggish. I noticed that the temp was about 260 degrees so i quickly shut it off. I opened the engine compartment and a lot of steam came out. the next day i started the boat up and it ran like normal. I checked the oil and it looked a little like chocolate milk, also, the breather tubes from the valve covers had whitish-brown foam coming out. I'm pretty sure i blew a head gasket and water is getting into the oil. My question is, can you still run the engine with a blown head gasket? I'm probably going to replace the engine but i still want to run the engine as long as possible. I ran the engine out of the water for about 10 minutes and the temp seemed fine. It also feels like the engine still has plenty of power. Will the engine run fine, then all of a sudden seize up? Or are there signs that show when the engine is about to seize?<br /><br />thanks. <br />sorry for long post
