Blue lower unit fluid leak. 1988 70hp. when i turn on the garden hose muffs
appleo
I suppose it’s a internal seal.
Turn on the water garden hose muffs and watery blue goo dripping from where prop meets gear case
Thoughts on what
parts i should order before i drop the lower unit?
any secret tips .?
thanks. appleo
appleo
More info
1. Not gear oil. gear oil drained and is tan
2 motor not in the water for 5 years
3. found one carb overflowing. re. mouse nest in throat 🙄
4 believe this mercury i’s thru hub exhaust
Thinking now the blue is gas/water/oil combo. carb sent excess gasoline out the exhaust.
will retest when sun comes out
The Force power
For sure a thru hub exhaust and yes it most likely the un-burnt oil/fuel mixture running down the exhaust
I hope you're not using 2-stroke oil for weed wackers/lawnmowers etc.
USE [h=1]Quicksilver Premium Plus 2-Cycle Outboard Oil TC-W3[/h] Less smoke & your engine will thank you
jimmbo
Looking at your 'Tan' Gear Oil, I would say it has water in it. So do what racer suggested, get the gearcase pressure checked
