One of the blue plastic drain plugs broke on my water pump and when I removed the plug there is residual plastic stuck in the threads that I can't get out. I was thinking of tapping it out. Anyone know what size tap I need.
Thank you
Keith
If the plug is inside a plastic fitting, just do as QB mentioned to remove or buy another. If its in a metal one, you can apply a little heat (not a lot) but should be able to loosen it up.
Try to replace the O-ring every few winterizations and they don't need to be much more then snug.
There are some brass/stainless plugs and fittings which can be used to replace them,
