blue sea panel switchboard 4308
UncleWillie
The directions seem clear enough.
For wiring, follow the diagram below and these steps:
1. Connect the Bicolor Bow Lights to Switch #2.
2. Install a 16 AWG jumper wire between the “NAV Diode” tab and the output terminal of Switch #3. <---<<<
3. Connect the 360? Anchor Light to Switch #3.
Where is the confusion???
UncleWillie
You jumper the tab to "The Output Terminal of Switch #3."
The same place you connect the Wire going to the White Anchor light.
2. Install a 16 AWG jumper wire between the "NAV Diode" Tab and the output terminal of Switch #3. <---<<<
When you activate Switch #2 The RED/GRN Bow Lights will illuminate, along with the White Anchor light, as if you switched #3 ON also.
When you activate Switch #3 The White Anchor light will illuminate only.
