- Jul 18, 2011
- 18,192
For some unknown reason the left headlight on my car has begun to fog up with obvious moisture/water inside. Upon some research, I have discovered that the headlight (really a headlight assembly) is supposed to be completely sealed.
Somehow the driver side headlight has developed a crack of some sort. . . . No damage to the car, so I'm not sure how these things just crack on their own . . . but I guess they do. Anyway, the moisture inside has led to functional problems . . . the parking light within the unit is out and now the car tells me that the "adaptive headlight system" is malfunctioning . . . What's an 'adaptive headlight' I ask myself
Anyway, I got an annual vehicle inspection due by the end of June, and it certainly won't pass as is. So, I decided to look into fixing it. It turns out that you basically have to disassemble the front of the car to remove the headlight assembly . . . and the cost of the part is $1,000 and up
. I cannot imagine what a dealer would charge to replace it. . . .
@Scott Danforth was right about these cars - electrical stuff just breaks for no apparent reason.
