Re: Boat and trailer weight - pulling
Thanks, everyone
reelfishin, does your estimate account for the motor, gas, etc?
If it is 1500 lbs then I can use the CRV to pull it.
Since pulling the boat, I feel like the transmission is not right on the CRV so I'm trying to verify that the boat isn't too heavy. I had an oil change before towing for the first time and wonder if something happened there..like using the wrong fluid (Honda requires special transmission fluid). By "not right" I mean it shifts hard/jerks when shifting.
I appreciate the input.
I had a 17' Starcraft trihull on a small tandem trailer that weighted in at about 1740 with a 50hp Mercury outboard and 12 gallons of gas on board.
Your boat is shorter and on a lighter trailer. My boat, a 17' Starcraft Capri is listed at 900lbs in the original brochure, plus the motor, battery, and fuel. The rest is trailer. The 1740 number is an actual weight on a CAT scale at a nearby truck stop.
I have a 16' runabout with a 40hp Johnson on a single axle Bandit trailer that weights in at about 1130lbs total, three of us carried that boat over from it's old trailer minus the motor, battery and fuel with no real effort.
If yours is heavier, I'd look close at the possibility of it's flotation foam being saturated with water.
How many miles on your CRV? Sometimes even a proper fluid change can create or expose existing transmission problems on higher mileage transmissions. Is it still under warranty? What did the fluid look like before it was changed? What led you to have it changed?
I wouldn't go much more than say 1500lbs when towing with that Honda, but I do have a neighbor with a CRV that pulls a fairly large pop up camper all over with his with no problems so far. He's been all over with it and it seems to do ok, but he don't keep vehicles long. I doubt if he'll keep it long enough to see whether or not it will hold up. The trailer has got to be near 1500lbs, maybe a bit more. A lot of how a vehicle holds up to towing has to do with driver habit. Take it easy and drive accordingly, and it should do fine.
