Re: Boat and trailer weight
MB<br />You've stumbled on to the answer
to your question. That cut-away van your motor home is sitting on is rated to pull 7,000 to 8,000 lbs. But most class C motor home builders (until recently) would not rate their motor homes to tow more than 3,500 Lbs
ONLY because of their frame extensions (kinda makes you wonder about how good a welding job they've done).<br />I have a 1995 22' class C on a Chevy C30 5.7L(350CID) with a 4.10 rear end. GVW is 10,500 and GCVW is 13,500. I tow a 20'center console boat on a tandem aluminum trailer(600#).Boat,motor and trailer with no gas, and no anchors, life jackets,etc. weights 3,260#.The boat weights 300-400 lbs more than the manufacurers literature said it did.
I do have a transmission cooler, and surge/disc brakes on the trailer.(I sure can tell when those brakes aren't working).You should not have any problems with your rig once you get that heavier duty hitch installed. Your trailer if it's steel would weigh around 900-1000# -that's just a wild guess.
