Boat corner cap protectors
javajunkietodd
Hey all. I have a 1993 19 1/2' Sea Nymph deck boat. Aluminum hull. All is good but there never has been (since I've had it) any corner cap protectors or nose protector either. I know Lowe purchased Sea Nymph and I'm obviously not looking for OEM. But would anyone have any ideas where I might find something aftermarket? Originally these were a hard plastic type material, but any material will work if the angles are at least close. The nose piece is a 97 degree angle. The 2 forward angles where the forward and starboard and the forward and port sides meet are about 145 degrees. The stern corners on each side are 90 degrees. And the transom corners are about 113 degrees. I'm no expert as you can tell, but if anyone has any ideas - thanks in advance.
jbcurt00
Have a local fab shop weld up 1/4in plate alumimum to a cardboard mockup you provide
Buy a whole derelict boat similar to yours and salvage the transom end caps and bow cap.
Lookup MichaelPs urethane end capsnon ebay.
JimS123
I have a Sea Nymph as well, and the corner protectors are cast aluminum, not plastic. Regardless, I can't imagine why anyone would take them off.
My only suggestion is to buy some starboard and fabricate them yourself. They are not going to be available and a machine shop would undoubtedly charge more than anyone would be willing to, pay.
