So I ran the boat out a couple weeks ago and I hit a sand patch and I tried to steer the boat away but as I was leaving the shallow area and I felt a sudden push forward for a second but after that the engine ran fine for about a minute or two which it then shut down and didn't start. I replaced the spark plugs and tested them with the spark tester and with the multimeter tested the coils I also removed the kill switch for testing purposes and had to manually move the starter up so it makes contact with the flywheel and spins. Now when I try cranking the engine it spins fast and leads to multiple backfires out of the exhaust. What could be going wrong or what should I try next?
