Hey Guys,
I'm posting this to see if my gut is right about this one.
Recently purchased a boat that appears to have a solid floor when I walk on it. Now the kicker is for roughly a month or so before I bought the boat the seller took the cover off and gave it to another buyer on this other more expensive boat he was selling.
The floor has been rained on during the last month, rained bad the day I drove the boat home. I let it sit for a couple of days to air out, now is properly covered and 4 days later the carpet is still full of moisture. The boat cover is allowing proper air flow.
Now with the highs only being in the low 40's and low's in the 20's should I be concerned the floor will freeze or ice up?
Will the floor on it's own loose the moisture without serious floor problem's?
Do I need to shop vac the carpet as much as possible to remove moisture?
I was hoping natural evaporation will allow the floor to breath and heal without the floor having any major problems / defects come spring..
Your thoughts?
Your thoughts?
