Boat floor replacement
JBBarry
I have a 1994 18 foot Starcraft 1810ss - a typical fiberglass I/o bow rider. I am replacing the floor on the port side. Do I need to use marine grade plywood or is standard exterior grade good enough? Should the underside of the floor be coated and if so with what?
Thank you,
JBB
chevymaher
If the floor is bad chances are it is alot more than that you got to replace. Boats rot from the bottom up. Floor is the last thing to rot
JBBarry
Thank you for the prompt replay. The idiot who owned the boat before me had a problem with the port side seat. He did a makeshift job to refasten it to the floor and put a lag screw through the gas vent line. Over the past three years the foam under the floor became saturated with gas and then rotting the plywood from below. I have the demo done and now ready to put it all back together. The fore/aft stringers are fine. I need to replace a small section of stringer just adjacent t the leaking vent line. All else is sound.
Woodonglass
I agree with CM but to answer your question, Ext. Grade Normal plywood will last as long as you own the boat and longer. The key is the resin/glass coating. The underside of the deck should be coated with a coat of resin and then another coat of resin with CSM applied. Same for the top but I'd use a layer of CSM and then a layer of 6oz cloth.
Woodonglass
Chopped Strand Mat. Check out US Composites online. Use their 635 Poly Resin Probably gunna need 2 gallons or resin and 3-4 yards of CSM and the 6oz cloth
JBBarry
Thank you, again. What weight CSM would you recommend? Also, I will need to refill with foam. Might you have a product recommendation?
Woodonglass
USComposites online will have ALL you need. 1.5oz csm and 6oz fabric. 2# foam is all you need. Calculate the cubic feet that you will need to fill and buy the right sized kit.
JBBarry
Thank you, all. One of the worst jobs I've ever done but my only alternative is to take it out and sink it.
Woodonglass
Yeah, boat restoration is a Hot, Stinky, Sweaty, Itchy job but...In the long run she'll be better than factory and you'll KNOW that it was done right and you can depend on it lasting a good long while.
JBBarry
Thank you for the encouragement. Three more questions, if you will. Should I run a bead of some type of adhesive like maybe 3m 5200 where the plywood rests on the stringers? The original installation was put down with 1 inch staples. Do you think stainless screws would be better? Lastly, referenced earlier is "2# foam is all you need". Are you referring to the 2 part expandable foam? Is there a brand or something more specific I should be looking for? Greatly appreciated, thank you. JBB
Woodonglass
I'd recommend using PB (Thickened Resin) on top of the stringers and plain old deck screws for the deck.
I'm talking about a 2 part foam that's sold by the weight of the finished product by cubic foot. 2# per cubic foot is whats most generally used. Check out USComposites online. They have all your supplies, at good prices and good explantions about all the products.
JBBarry
Thank you, sir. My project tomorrow is cutting and fitting the deck plywood and ordering all other supplies. Hopefully next weekend I will be installing and glassing the plywood and the weekend after filling with foam. I am in in Western NY so hopefully I will salvage half of the boating season. If you happen to have some expertise in steering problems I would appreciate any advice you might have with regard to most post in that section of this forums. Thank you, JBB.
JBBarry
Sorry about my typing skills. My wife can type a million words a minute. I cannot spell very many words a minute and find it difficult to hit less than 4 keys at a time.
