Boat floor
vector24
My 81 vector hydrostream`s floor is alittle rougher than i like can i use rino liner or anything thing like that to use as a floor/sealer i have carpet but i`m afraid of the wood soaking and taking water to the bottom of the boat thanks if you know a better method please inform me
dvan1901
Re: Boat floor
To clarify; you currently have carpet installed? Have you pulled the carpet up yet? If you have not, pull it up and see what you have. IF the floor is sound, then sand/grind the glue off, put a good coat of epoxy down to seal it all, then use something like a rhino liner (not black though), or even better may be Durabak. It's pricey, but seems really good and several here have used it.
JasonJ
Re: Boat floor
Your post makes it sound like you have a raw wood floor. If this is the case, is this something you did or something you "inherited" at purchase? That boat should have a floor that is fiberglassed in, you don't need to do anything if all you are doing is glueing carpet down If the fiberglass is sound, and the floor is solid.
Make sure you don't have the ever popular piece-of-plywood-screwed-over-rotted-floor trick. it's a time honored tradition for people to just slap a piece of plywood down instead of properly repairing it, which involves removing all rotted floor material, the stringers if rotted, and repairing the transom if rotted, then glassing in a new floor.
Truck bedliner material is overkill and not necessary in a boat. There are products like Evercoat No-Skid that is a rubberized material with traction niblets that works very well and is lighter and cheaper than truck bedliner, and is intended for the application.
vector24
Re: Boat floor
I have a floor in the boat but it is a quick plywood repair i am a little worried about pulling up the hole floor, I dont want to damange anything and i`m not sure what i will attach the floor onto if i do. but the rino liner is what i was hoping i could use in replace of carpet and seal the floor to keep water from getting in the bottom perhaps i really need some info on this repair.
vector24
Re: Boat floor
Ok i have problems i just pulled up half the floor toward the back of the boat and below the so called fiberglass sheet of factory floor was mush wood and below that was the bottom and i seen a place on the bottom that was even a little soft what do i need to do please help i like my boat its a 81 hydrostream vector with a 150hp outboard if u need that info.
Nova II 260
Re: Boat floor
OH, OOH. Vector, I hate to be the first with bad tidings. You have some home work to do. Read everything on stringer and floor restorations. just do a search in this forum and else where. Might as well start here my project
JasonJ
Re: Boat floor
Vector, click my link, you will find a similarity in the horrors.
I almost bought a Vector a few years ago, btw...
Indymike
Re: Boat floor
Check out my Journey link below. It's not all bad...You will intimately know your boat when it's done.8)
Saskatoon2005
Master Chief Petty Officer
Re: Boat floor
Your work looks very good, keep on going, and the pic updates are great too...everyone loves to watch a project unfold....
