Boat fuel tank
gwg
I have a 1988 Bayliner Trophy 2102, and it has a 94 gallon fuel tank
The model number on the tank is 49-94-AF. Does any one know who is the manufacture of this tank?
jbcurt00
Looking for maker to buy same tank for replacement of current tank?
GA_Boater
What is the tank material - aluminum, plastic, steel?
Should be a tag on the tank. However there are a few dozen certified tank manufactures that supply the small boat builders. About 10 in Florida alone. I think there are about 6 in Tennessee
gwg
Hello,
Im not buying a new tank, the tank is made of aluminum, and I couldn't see the manufacture name, as it was full of crud. I can get the serial #. I guess that would help as well.
GA_Boater
The plate or label with model number should have the manufacturer name.
Is there a problem that you need the name of the maker?
if its just full of crud.... clean it.
