findinghomer
- Nov 7, 2009
- 271
Hi guys, this is a 1997 Mercruiser 5.7 v8. Long story short, I got stranded on the water last night, after running fine all day bc It wouldn't go into gear. I was on plane, and the boat made a cavitating sound. Assuming it was just cavitation, I just carried on. but the third time it stalled. Never to go back into gear again. I got the boat to my driveway and checked some things. When I put the boat into gear , the prop does lock to whichever direction respectively. So it appears that the shift linkage is shifting the lower unit properly. But when you start the boat and put it into gear the prop does not spin. I pulled the outdrive, and then separated the lower unut. With the lower unit off, I can turn the prop and I can hear it spinning the impeller as it turns the vertical drive shaft. So it appears everything is working as it should down there? Everything appears physically fine from the out drive. Nothing obviously broken. Before I pulled the outdrive, I checked to see if it was drawing in water to the engine. It doesn't appear to be. I am afraid it may be the engine coupler, is there anything else I should look for? Or is there any othet indication for me if it is the coupler? I peered in there with a flashlight and it looks ok but I don't know how sensitive those things are. Any help would be appreciated thanks
