Hello All,
I'm trying to troubleshoot the horn on my 2004 Tahoe Q7. If I remove the horn from the boat and connect it to a 12V supply, the horn works. Using a multi-meter, when I press the horn button with the power switch on, I see ~12V so I'm assuming the horn switch is working correctly and I'm getting the correct voltage to the horn. When I connect the horn to the correct leads and press the horn button with the power switch on, the horn clicks (sounds like a relay clicking) but the horn does not work. Is there something I'm missing in my troubleshooting?
Thanks in advance.
Thanks in advance.
