boat hull problem
texas_angler_2002
i have a 85 procraft and the rubber part that goes around to middle of the boat is coming off. under it it has screws and there backing off. if i took off the rubber coating where can i buy mnore or will i be able to use it again once i have the screws anchored.
clanton
Re: boat hull problem
Sometimes you can put 5200 sealer in the hole and on the screw, and it will hold the screw in. I am sure there is better ideal, but this will work for a while.
