boat info-the library
tlh 178
is anyone else getting a error code on the library or is it just me? i've looked there atleast 25 times with no problem. today,have gone there a few times and keep getting error message!
Captripp
Re: boat info-the library
Yes, I'm having the same problem. Does anyone know what gives?
Fed
Same here, I've often wondered how they could 'get away' with publishing those manuals on the internet because from what I've seen any genuine manuals that pop up get removed pretty quickly.
Maybe they had a special deal or something.
As clunky as the site was I hope they get it back up.
What are you looking for?
tlh 178
i'm trying to find the strainer screen in the cooling system. i did find one, but it was in one of the oil lines. 2001 optimax 135.
Fed
On a slightly earlier model it's located on the top of the exhaust plate, the water then goes via a hose to the compressor.
So, standing behind the motor you should be looking straight at it right at the top of the exhaust plate between the cylinder banks.
Faztbullet
This was a good site and people started posting about it and Merc shut em down, just like the other site 1marine I think it was callled..
Loose lip sink ships.....:grumpy:
tlh 178
thanks fed, i'm doing new water pump,impeller and new thermostats. figured i might as well clean the screen while i'm working on it!
Fed
Boatinfo library is back up.
