chris in va
- May 4, 2003
- 410
Motor hydrolocked on July 4th. I suspected the flywheel had some missing teeth, and sure enough that's what happened. I already knew the flapper valves were disintegrated, which was most of the reason why water got sucked into the exhaust.<br /><br />I implore all you guys to check the condition of the valves. It's such an easy thing to do and may save you the headache I just went through, not to mention the expense.
