jimmwaller
- Nov 30, 2013
- 274
Hi all,
Question about a boat I'm thinking about buying. Owner says it's a LoneStar Riveria (Riviera?) and it looks like it's in fairly rough shape. The interior looks like it has had some kind of epoxy (gluvit?) treatment. I'm not seeing any leaks out of the rivets. BUT:
On the very bottom, there's a small keel that appears to be dripping when the boat gets pulled out of the water. However, I'm not sure this keel is actually attached to the rest of the boat. I attached photos (sorry, these are all I have, I only snapped a few and it's not actually my boat yet!). But you can see that there aren't any rivets around there. I kind of wonder if that keel section is hollow, and it fills with water when the boat sits in the water, and then the water drains when the boat is removed?
A good test would be to fill the interior with water and see if it drips out, but the owner just popped it into the water, and then opened up the drain plug and filled it a little with water so I could see that it doesn't leak. When I went under to check for leaks, I found this very slow drip from this keel. It might be water from the hull dripping, which would be bad. It could also just be contained to this little keel area.
Anyone know anything about these boats or similar construction? Is this keel actually connected to the hull somehow, so if the keel is dripping, the boat is leaking? Or is it possible that the drips from this keel are just water that was only trapped on this keel section? Or am I doing a terrible job of asking this question?
Thanks!!
Thanks!!
