Boat lifts uneven under acceleration
Draft
I have a small 12 foot livingston with a 15 hp honda 4 stroke. At rest the boat is balanced but under accelleration and at top speed the right side of the boat is higher. I know it has something to do with the engine, but I check measurement and everything is fine. what else could it be?
Home Cookin'
Re: Boat lifts uneven under acceleration
Shift your ballast to starboard (i.e. slide your fat butt to the right)
Ayuh,... try changing the trim....
david_r
have you measured to make sure the engine is exactly in the middle of the transom?........... a little goes a long way, especially in a small boat.
Draft
thats what I do now, I shift my butt to the right. lol
I'll triple check the measurments to see if its exactly centered.
puddleboater
If the motor is centered correctly, check if your outboard has a torque tab underneath the ventilation (aka cavitation) plate. It looks like a small skeg. If you have it, they are typically adjusted by loosening a screw. You can fiddle with it by rotating either left or right, to compensate for the prop torque.
Another trick I've seen and read about, is installing a trim tab on your transom (on the affected side), to adjust the pitch and running attitude of your boat. I'm not referring to the hydraulic tabs; there used to be fixed trim tabs available years ago and they might still be around today.
If all else fails, perhaps you can also shift your starting battery or fuel tank to the affected side. :D
Good luck!
wizbang 13
Try trimming up one hole. It is probally the port being hauled down. not stb. going up.
