Just bought my first boat. Its a tracker TX 17 with a 40 HP 94 Mercury 4 cylinder, 2 stroke. I noticed a little oil coming out of the small ports just below the junction of the lower unit and main body of the engine (I think they are the pee-holes). It begain to leak when I trimmed the motor up to store in my garage. No leaking when fully trimmed down. No water in the lower unit and no frothy or white oil. When I pulled some oil, it was clean and yellowish. After a little research, sounds like I have a leak in my lower unit and should have it fixed soon, if not immediately. I am fairly mechanically inclined, should I attempt to replace the seals or pay to have it done? Also any recommendations on if I should run it at all until its fixed. If I can believe the guy I bought it from, he has been running it for months now. Thank you for your help. Chris
