Boat Paint?
firefighter438
I recently bought a boat and did alot of fiberglass repair.I would like to know what kind of paint to get.would like to go very cheap.bottom paint is done.so its just the sides that i have to do.preferabbly something i can buy at lowes.boat will be trailered most of the time and only used in freshwater.PLEASE HELP
JCF350
Re: Boat Paint?
I believe Lowes carries Valspar. Can't go to cheap or it won't stick.;)
Joe_the_boatman
Re: Boat Paint?
stay away from latex (for now). Not many people have experience using it on boats around here, so the verdict's still out.
Oil based exterior should work. Lots of folks have had good results with Rustoleum by the quart or gallon, and it's fairly cheap. Most anyone will tell you that any paint job is only as good as the prep job beforehand.
mtduckhunter
Re: Boat Paint?
sorry to jump in on your post firefighter, but what about rustoleum spray paint with a sprayed on clear coat?
Gary H NC
Re: Boat Paint?
Spray paint will be hard to get even on that large of area unless its sprayed with a gun.
Something cheap would be Valspar industrial paint.Sold at Lowes.
Rolled on with a closed cell roller it will look good.
You could step up to the Interlux paints but then your getting into the 100 bucks a gallon or more.
tashasdaddy
Re: Boat Paint?
this is a 1966 Sport Craft Sportsman, hull, done with roller rustoleum with roller. deck with Krylon, acrylic latex enamel.
Re: Boat Paint?
Ayuh,.......
Rustolium gets My Vote......
petrey10
Re: Boat Paint?
I am going to be using acrylic enamel on the fiberglass work I did on my jet ski. I just found the finest paint brush I could get. It won't matter too much because its the very bottom but I will still know its there.
