Boat painting
RiL
Can a jel coat be painted and if so with what paint?<br />Thanks,<br />Rick
rage
Re: Boat painting
Interlux says thiers can. A friend painted his last year and is looking good still. Manufacturer just says to sand well.
RiL
Re: Boat painting
Do you know what type paint he used?<br />Thanks,<br />Rick
BillP
Re: Boat painting
It can be painted with just about anything you want to use...it will stick and last for years and years. Cheap enamels to high end 2-part mixes work. Water based latex doesn't do as well as enamels but I've seen this work ok but not great because it is soft and scratches easy. Oil based Porch N Deck type enamel works almost identical to the bottom line "boat" enamel. The key is getting the surface prepped right. Pick a type with an application system (temp, weather, etc.) you are comfortable with and go for it. I'm speaking from experience...other people's may vary, it isn't an exact science.
Tinkerer
Re: Boat painting
Agree with Billp, except I think some of the top grade latex exterior paints are probably reasonably tough and pretty durable, and water base is easier to apply and clean up. But high gloss latex is still less shiny than high gloss oil based enamel. Personally, I'd go with the enamel or a polyurethane or epoxy type paint. Single pack anything is fine for a trailer boat that spends most of its time out of the water. <br /><br />Basis of any good paint job is preparation. Also the most boring and lengthy part of the process, so it offers greatest temptation to cut corners, which you always regret later when the imperfections show up through the top coat. And the more glossy the top coat, the more visible the imperfections will be.<br /><br />Shiny surfaces like fibreglass need a good key for the paint to grip. If it's absent, the topcoat, whatever it is, will go on OK but chips off easily later because it's not properly bonded to the base.<br /><br />A light sand is good, but even better is a light sand with an undercoat that's designed to bond to the fibreglass. There's things like Penetrol and ESP or special paint-based coats from various manufacturers. <br /><br />Be careful to get rid of all contaminants and waxes, especially silicone, off base before applying any coats of anything. Sand first then wipe down with prepsol (automotive prep wash - any store that sells auto paint will have it). Not strictly necessary in a lot of cases with non-auto paints, but guarantees a clean base to start with and avoids nasties coming through the top coat.
RiL
Re: Boat painting
Tinker,<br />Thanks. Do you find that paint stores carry these paints or do you need to order them? I tried several stores here and found nothing and they did not know where I can find this paint.<br />I thank each of you for your information.<br />Rick
jamiewashere256
Re: Boat painting
I have had great luck with Interlux brightside polyurethane. Wherever you find the paint, you will usually find thier painting guide. It's pretty good gives alot of good tips. You can also look at thier site www.yachtpaint.com and the same content is there.
Tinkerer
Re: Boat painting
RiL<br /><br />Don't know about Texas, but I've seen marine paints only in boat shops here.<br /><br />I'll retract what I said before about water-based paints. I've been doing some test panels for painting my fibreglass boat. Even top quality latex won't resist knocks and scratches as well as enamel. I'm thinking I'll probably go with a sprayed marine full gloss as I don't have the respiration air gear for spraying two pack polyurethane and it's dangerous if sprayed, but supposedly OK if it's brushed or rolled in well-ventilated areas (just like they told us tobacco and asbestos were fine - pardon my cynicism)
