boat planes to one side!!
jimjim11
hello all
I have a 1990 bayliner 1700ls with a force 50hp. This is my first boat and it was my first time out. I was happy with everything except when i went to full throttle and the boat planed out it would pull hard to one side or the other and the boat would lean way to the side the boat pulled to. so we were riding with one side way low to the water and the other was up in the air. i dont think it was a weight issuse because it would pull/ tilt to different sides randomly. any ideas or help? thanks evereyone
Texasmark
Re: boat planes to one side!!
Sounds as if you may have water in the hull, below the deck. Shifting weight like that could do what you say as the water moves to the lowest spot, be it port or starboard.
Mark
Ciera2450
Were you making a turn?
People moving around the boat?
jigngrub
Sounds like your trim tab is missing on the bottom of your motor.
jimjim11
it was empty when i went into the water, when i pulled the plug when i got out their was what seemed to be alot of water, that could of beeen the proplem. how does so much water get into the hull in ony 2 hours on the water. their was only two of us and we were sittin still. trim tab on my motor or boat? i was not aware that motors had trim tabs? but i will do some research and see what i can find and take a look at my boat. thanks for the responses, anything else would be helpful.
Maclin
A LOT of water rolling around can make a difference, can get "stuck" in different compartments under the flooring. How long did it take to drain all the water out? 1 minute? 5 minutes?
(I hope you have a bilge pump :eek:)
Does your boat have an add-on foil/fin mounted on the motor?
Do you have and use power trim?
jimjim11
it was like 3 or 4 min i think. I have a portable pump that came with the boat when i bought it. might have to put it in. any ideas where to put it without cutting holes? it does have a fin addon think that can cause my proplem?
Maclin
You have muliple problems it seems.
3 or 4 minutes sounds like a lot of water. You need to figure out where it is coming from. That much after a while on the water can make a small boat pitch around funny. Not to mention it getting into places and things it can do damage to. And there is that sinking thing too.
The fin addon can affect a boat adversely. The lift they provide is applied only to the middle of the boat, and if they keep on lifting at speed then the boat has to "fall" to one side or the other. Turning at speed with one can also be an adventure.
