boat planing question
Boat-ryder
first off ive got a 16ft aluminum jon with a 25hp johnson.my boat is also a semi tunnel hull,ive been running this boat all summer not really having any problems other than its kinda slow but the other day i was in a hurry goin back home and was running the boat wide open and every now and again letting off a little bit.the boat raised higher than normal and started cruising faster than before.so apparently that was the first time ive actually had it planed like its suppose to.my question is about the fins people mount to the foot that are suppose to help this problem.is my motor to small to do this?(never seen one on anything smaller than a 40).if it is what else can i do to get on plane? thanks
Joe Reeves
Re: boat planing question
Check with any dealership on the availability of a hydrofoil (fin,wing, etc) for your model engine.
Also you might check how the engine is mounted...... With the boat on a trailer, back off and sight it from the side. The cavitation plate just above the propeller should be about 3/4" below the bottom of the boat, and on the same angle, parallel with the keel/bottom of the boat.
Boat-ryder
ok ill check that out this afternoon,im doing some research now and just found some stuff on the trim tabs.never heard of them before but would they be a better option? not crazy about drillin holes in my motor but whatever works.
