Boat position on trailer not right
beckoning
This is going to be hard to explain, but I'll try. I have a 19' aluminum boat weighing a little less than 2,000lb with motor, kicker, 25gallons of gas, and gear. I need to know how to adjust my rollers so the bow comes into the rubber V, and the bow eye comes under the roller.
My tongue weight was about 1% and pulling was dangerous. To make it between 7-10%, I moved the winch bracket forward on the tongue about 8-10", and moved the rear roller rack forward about 10", otherwise the rear-most rollers would hang out beyond the back of the boat. All seemed good. I put the boat on the trailer and the tongue weight is about 160lb. However, for some reason, the boat rides high on the rubber V so it is impossible to have the winch strap be below the front roller. I can't seem to pull the boat all the way into the rubber V at the front, or have the bow eye come in below the roller.
I know this is confusing, but any thoughts would be helpful so the boat sits on the trailer more balanced instead of trying to be nose high.
smokeonthewater
Re: Boat position on trailer not right
move the front rollers further outboard to let the bow drop lower
roscoe
OR put everything back where it was, and move the axle back 10".
bonz_d
In this case it sounds as though roscoe has the best answer. Unless of course the spring perches are all welded in place. Then it would be a little tougher but still the best idea.
Huron Angler
If you've got room, it might be a LOT easier moving the winch post forward, than moving the axle back. Both will provide more tongue weight.
Downside to moving the winch post forward is that you'll need to back up further to float the boat off the trailer when launching.
