Re: Boat pulls hard to the right
I not an expert but have a couple of Queations. One is motor mounted low enough that both top and bottom of prop are covered in water?? Does it pull the same at all trim angels?? Any thing on the hull to cause more drag on one side?? Does it pull before get on plane, just after reaching clean plane, and at full throddle??? I assume you are talking about when the boat is up on plane. Adjusting the motors skeg is the normal answer for high speed. Some radical props can create this type of problem but adjusting the skeg should still make a big difference. Not 100% sure you are talking about an outboard, but outboard that are mounted real high trying to get most speed sometimes have your type problem. If it is a inboard power stearing pump possible. I know not much help but trying to give you some ideas and info to get to report back and someone will be able to help you.
