Gas Giant
- Aug 8, 2010
- 239
Hey guys,
Engine is a '78 Johnson 85hp motor, red plastic above-the-deck fuel tank, new primer bulb/hose.
To make a long story short, the engine runs well, but only if there is fuel in the carbs (imagine that). I can prime them with the primer bulb, and it does get hard. I did that and checked for any leaks in the fuel lines leading to the carburetors or fuel leaking out of the carburetors from stuck floats. I didn't see any. I should mention that I pulled both carbs off and cleaned them out about a month ago, but didn't try to run it until today.
Boat fires right up after that, and runs great - until it burns up the fuel in the carburetors, at which point it not surprisingly dies. It won't restart again unless I prime it again. (It will sort of sputter, but not run, if I don't prime it)
Since I can't find any leaks in the fuel lines and the primer bulb does get hard, I'm thinking I don't have a primer bulb problem or a fuel/air leak problem. I'm thinking I have a fuel pump problem - the fuel pump isn't sending fuel to the carburetors, so after it burns up what I sent to them with the primer bulb, it dies.
Would you guys agree, based on what I've told you, or is there something else I could be overlooking? I often overlook simple things when I get frustrated, so sometimes it helps to have a 2nd opinion from some folks who aren't frustrated.
Thanks!
Thanks!
