Newbee here. Took the boat out of storage to us, a 1994 Regal 182SE I/O, and noticed the springs sagging and axel bent on single axel trailer. Trailer place looked at it and said overloaded and suggested weighing it. I did and it came back 4300lbs for boat+trailer! The dry weight of the boat is 2250lbs and trailer 500lbs. Looking across the other posts about water in the compartments with foam and so drilled explore hole from side inside ski storage and found water at bottom of compartment and wet foam Assuming this is spread throughout, could it account for an extra 1500lbs or so of extra weight to account for the difference? And is there any way to drain out what would be hard to believe almost 200gals of water buried somewhere inside? Thanks.
