Boat shopping questions
markwarren66
Hi! <br /><br />I'm in the market for an 18-19 foot bowrider. It will be used on inland lakes for day trips and water ski/tubing activities. <br /><br />This is my first boat, so I don't want to go crazy and spend a ton of money. Looking for something in the 2000-2004 range, $8-15k price range. <br /><br />Will a 135hp I/O pull a 220 lb man on skis? Or should I look more towards the more expensive 190-220 hp engines? <br /><br />I want to store in my garage, which is 22'5" deep, so I think I can fit a 19' with the tongue to the side, but not sure. <br /><br />And advice for a newcomer?<br /><br />Thanks!
studlymandingo
Re: Boat shopping questions
A 135 should pull a 220lb skiier with no problem. You may want to have a couple of props on board though, you'll need a low-pitch for watersports so you can get the hole-shot you need to pull up out of the water. That may spin too fast for general cruising. If you can do a couple of sea-trials on different boats to find out what model is best suited for you, that would be your best bet.<br /><br />Welcome to iboats!
Chris1956
Mark, You might consider an outboard on that boat. It will be lighter and therefore give better performance, and be easier to trailer. Maintenance on outboards is much less than I/os. Oil injection is pretty standard on the newer motors.<br /><br />I do not think that boat will fit in your garage, with out the tongue sticking out. Also, on a boat that size, it may be a bit tall for the door opening.
Texasmark
Measure any boat you want to put into the garage including the outdrive and trailer winch even if it has a folding tongue. You'd be surprised at how the inches add up.<br /><br />Agree on OB rather than I/O. Having had ONE I/O will not have another.<br /><br />135 is plenty on an 18ft boat with 3 or 4 people on the excursion. We had an 18ft trihull, very heavy, bow rider, 125 Johnson and 4 children and we all would make a day of it. Pulling doubles most of the time on 2 skis, usually 1 on slalom.<br /><br />Had one general purpose prop which was SS and had a 17" pitch. As I recall the lower unit gear ratio was 2:1 (makes a difference when talking about prop pitch). <br /><br />Did well on hole with a skiier plus top end was 39 when lightly loaded. Didn't need to fool around with changing props with this setup. But nowadays, you can get ported props which have holes drilled in the side which allow you to run a higher pitch for top end and act like a lower pitch when you are trying to get out of the hole.<br /><br />Deep Vees ride smooth and after you get pounded a few times you will see why they are popular, or just get one and start out right.<br /><br />Most boats wind up stern (rear) heavy (especially I/O's) and this hurts your getting up on skiis (hole shot). You may consider adding trim tabs to the transom to help with lift.<br /><br />One final point. If you have rear seats and choose an I/O then I would go with the higher hp engines or possibly trim tabs would help. I had a light weight, aluminum , for the length of 18' (Starcraft brand), I/O with a 120 hp Mercruiser and I couldn't get out of the hole if both rear seats were occupied by adults.....15 more hp wouldn't have made any appreciable difference.<br /><br />HTH. Good luck and enjoy your boat......they're never big enough on the water and always too big on the land. My opinion.<br /><br />Mark<br /><br />Don't forget your tow vehicle. Need a big one for a big boat unless you keep in moored.
markwarren66
Thanks for the feedback. <br /><br />I have been looking mostly at I/O boats as I thought they might be shorter in length (fit in garage), but I guess if you lose seating to the engine what's the difference. They also seem to be the most available on the used market (northern IL). <br /><br />I do want to perform as much of the routine maintenance as possible. I'm handy, but not an engine mechanic. I think I can learn, though. Are outboards that much easier to winterize and such?<br /><br />Garage - I know that it's going to be close. I don't want to limit myself, but I also don't want to pay for storage...we bought a house with a 3-car garage in order to have a boat someday. I'm certain I can fit most 18' boats if the trailer tongue can be moved...19' is pushing it. My garage opening height is 7', so I'll just have to measure the boats.<br /><br />As for the tow vehicle, that's the only thing I'm certain of! I have a Nissan Titan that can tow some 9000 lbs. If only I could afford a boat that heavy...<br /><br />Lastly - when looking at HP ratings, are they the same for I/O and OB? Or is one inherently faster?<br /><br />Thanks again
KCook
Boats below 18' will be fine with the 3L. 19' and up need the 4.3L. There are also lots of models in the 18-19 foot range. Some of these designs will get by with a 3L, most will be better with the 4.3L. Depends on the exact design. There are lots of threads here for shopping boats in this size. Here are a few to get you started -<br /><br /> Loaded question (boat selection) <br /><br /> Need help choosing a boat! <br /><br /> Help me buy the right boat <br /><br /> Sampling entry level bowriders (18') <br /><br />Kelly Cook
Gfriedman
Originally posted by Texasmark:<br />HTH. Good luck and enjoy your boat......they're never big enough on the water and always too big on the land. My opinion.<br /><br />
could not have summed it up any better.
