I have a two part question. Forgive me for not knowing all the correct terms, I'm new
<br /><br />I recently purchased a Glastron Conroy and it has some places (looks like dock rubs) where the gelcoat has been scrapped. I think only above the water line but there may be some below it. Do I need to fix this? It seems that the fiberglass has not been cut at all, I should note Im not even sure I can see all the way to the fiber glass.<br /><br />Second part, so I accidentally slipped with my sawzal when cutting apart a steering cable and I just barely nicked the inside of the (hull?) to the right of where the motor mounts on. Barely nicked is defined as a cut about 3/16 in long and at its deepest you might be able to stick a hypodermic needle through the hole. It seems this is a tiny (smaller than a pin) hole in the part of the boat thats not supposed to have holes in it. Do I need to fix this and if so whats the best thing to do?
