For the last 3 months I have been trying to get my boat to shift into reverse and forward gear with no luck. I can only hit one gear, but not the other. I have adjusted the setup using the service manual several times with no luck. So it is either the shift lever, or the cable and the cable looks good so I am leaning towards the throttle lever.
The reason I say this is because when I shift into reverse, the lever does not stop at WOT until it is almost at the 4:00-4:30 position, when I would expect that it should stop at 3:00 position in reverse WOT. Forward WOT stops at 9:00 position.
Since this happens, it appears that something might have went wrong with the lever.
So, to my question.
my boat has a mercruiser 3.0L, Alpha one stern drive. Can I use any type of shift lever I want to replace the one I have, or does it need to be a certain type? When searching for a replacment lever, what type should I be looking for?
Currently it is a side mounted single lever, with neutral cut out, and outdrive raise/lower switch.
Thanks guys.
So, to my question.
Thanks guys.
