The_Only_Gert
- Aug 31, 2020
- 16
Hey guys have more of a generic questions so don't really think that my engine matters but I have a 92 Thompson carerra with a 4.3 merc...long story short I have battery voltage to my key, verified with a multi-meter, when I turned the key on I get a significant drop in voltage at the multi-meter. battery voltage was around 12.5 and when I turned the key on the voltage dropped to 11.5 or lower (can't remember the exact number) anyway on my volt meter in the gauge cluster the voltage was the same. I checked the battery and was still at 12.5 so I know I have a drop somewhere. I disconnected the output wire from the key and tested voltage and had the same 12.5 so I know the key is good. Now when i power the rest of the harness up is when I get drop. so I know its past the key, I've been cleaning connections and still haven't found the reason for the drop.
Here is why I started looking for the voltage drop. When running my battery's are at 14.2 give or take so I know they are charging. The volt meter however is only showing 12.8 ish and throughout the day the voltage on the volt meter drops lower (the battery's are still at 14.2 with a multi meter) my worrying is that I don't want to under-voltage my fuel pump and burn it up, since I know they run on the same wiring basically. Why am I getting this drop througout the day, alternator tested good, factory volt meter jumps to 12.5 when a direct connection is made between it and the battery. Thanks for any help guys.
