rovamachine
- Sep 7, 2003
- 5
1980-1981 merc 225 on v-20 wellcraft idles fine &<br />will rev over 5000 rpm in neutral. But when i put the motor into "F" i can not get the boat on plane<br />or over 1800 rev's . Checked compression 5 cyl's<br />showing 125-130 lbs, 1 cyl @ 75 lbs only.Removed head bore has small score in it would that cause it. o-yeah checked carbs all 3 very clean. new fuel before i started. If this is the problem is it worth fixing on that particular motor. motor looks new been sitting a long time.<br /><br /> thanks: andyadmas
