Boathead004
- Jun 16, 2016
- 9
Hello I am new to this forum, so go easy on me.
I have a 1980 200HP OMC cobra, and I am having shifting problems. So my problem is, my prop will engage in both forward and reverse but it turns very slowly. When it does engage it doesn't give me any kind of thrust, like it use to when it goes into gear. I manually try to put boat in gear by moving shift arm on the converter box but still nothing. Random thing, that is probably not good for my gears but i got prop fully engaged once I put boat in gear with tilt all the way up. My shift cable from my shifter to my converter box seem to be in good condition and operating correctly but its downstream of the converter box where the cable goes into a rubber sheath and down to my lower gear must be the problem. Need help diagnosing this problem as well as how to fix. Thanks
