Re: Boat won't go fast.
You really should check the tach. Something is not adding up, because 30mph at 3000 rpm is fairly fast for a 3.0L on a 19' boat. Check to make sure the tach is switched to the correct # of cylinders (small switch usually on the back). I'm propped for pulling on my 17.5' with 3.0 1.97:1 ratio and 19 pitch prop, and I get 30mph at about 3600-3800, topping out at 40mph when it hits 4600RPM, at which point I have to throttle back. I have it propped this way to pull skiers. With a 21 pitch prop I'd guess I would be at 3400 RPM or so at 30MPH but I have a smaller and lighter boat than yours.
If it is really going 30mph at 3000 RPM, then either a drive with a low gear ratio is installed or there's a really large pitch prop on there.
Boat speedometers are not real accurate either...
