JollyRoger87
- Aug 21, 2015
- 1
Hey guys. Have a slight issue my 92 four winns 190 horizon. It has a 5.0 omc cobra, with a Holley 2 barrel, and electronic ignition.
About a month ago, it left us stranded on the water. The motor wouldn't run under load and had a difficult time starting at all. Brought it back home, changed everything ignition related, one thing at a time, and found the culprit to be the coil. Runs fine now, except for one thing:
In the yard on muffs, it hesitates consistently at about 2800 rpms. On the water with a load on the engine, when it gets to this point, you have to baby the throttle to keep it from stalling.
Everything else seems fine, cruising along at part throttle away from the dock, no problem. WOT on the lake no problem. It's just this one point in the RPM band that gives you trouble. Any thoughts?
