have a 1987 omc 1.6 litre (135) hp with a vro system..i just brought the boat with the owner not being able to solve the problem,, please HELP,,the motor runs and starts fine out of gear,,when you open the trottle i only get 3000 rpms and it boggs down,,,BUT if i push in the choke button on the key switch and hold it then it jumps to 4500 rpm and takes off and runs get..when i let go of the key it bogs down again...help please i changed the vro,carbs cleaned, added a electric fuel pump, rerouted the fuel from the boats tank to external tank with a regular pump, and it still bogged..what can i try next
