bogging at mid range acceleration
moliver111
Hi guys,<br /><br />I recently had my carbs rebuilt on a 1989 mariner 60hp because the needle and seat were leaking gas and i have a problem. I took the boat out for a test run when i got it back and it starts great, idles great, takes off and runs for about 30 seconds and then it starts to bogg down. if i bring it back down to idle, it's fine until i try to accelerate and it will bogg again. I know you guys have responded to this type of problem before because i researched earlier posts but here is the part thats different. when i accelerate it will bogg at midrange powerband but if i throttle full, it runs good and keeps running at full throttle until i back down again and try to accelerate and it does the same thing over again. is there any mid range adjustment for the carbs or is there something else possibley wrong? boat ran great before rebuild. i have also lost about 5-7 mph at full throttle.<br />I would appreciate any suggestions or possible fixes.<br /><br />thanks a bunch.
Yepblaze
Re: bogging at mid range acceleration
The link and sync may need adjustment. (If so equipped)<br /><br />Otherwise, if the issue doesn't clear if the primer bulb is squeezed during "the bog", suspect the carbs need re-doing with attention to midrange response.<br /><br />If "the bog" goes away with a pump of the bulb suspect fuel connection, filter, or pump.
moliver111
thanks for the help. what do you mean buy "attention to the midrange". is there something specific that you can do to increase the midrange power when rebuilding as carb?
