Re: Bogging down
That's the most likely solution.
Can you get it running at high speeds and if so how does it act? or is it just in accelerating to get there?
Second most likely problem: Air-leak in fuel line. One test is to listen while pumping the ball.
Can you hok up a remote tank directly to the motor, to see if it's inside the cowl (back to carbs) or upstream?
Others:
pliers-tighten the ground on the battery (not likely your issue, though, but always good practice)
clogged tank vent (not as likely)
clogged fuel pick-up
fuel pump (does squeezing the bulb while it stalls help?)
