I have a '83 mercury 90hp that is bogging when full throttle is applied. It cranks ok and will run great at low RPM. A mechanic tell me the number 4 coil is irregular(jumping around) and could be causing the problem. I believe the problem is in the carbs. I have been through all three carbs twice and they seem to be good Replaced the gas lines and primer.What are the chances the problem is in the coils?
