tedsoileau
- Jun 9, 2016
- 1
I have a 1996 120 hp Force outboard. It runs good and can get up to about 5000 + a little but if I try to go full throttle it boggs down. I reduce the throttle and it runs good again. I can run it with no problem for a long time at rpm as stated above. Check compression--all 120+. Check spark--good. Check fuel output by disconnection hose to carb and turned engine--plenty of fuel. Tried pumping bulb while it was bogging down and nothing changed. Sounds like it surges--slightly while trying to go full throttle but boggs when full. Been reading and trying different fixes--but nothing changes. Any suggestions will be appreciated. Fuel was old but added new fuel--over half a tank. Thought it would have even it out. Gas looks good. Help!!!
