Bolt holes 85 hp-120hp
alden135
Will my 1969 85hp bolts line up with my 1990 120hp?
Thinking of swapping motors so I can actually boat this season.
alden135
Re: Bolt holes 85 hp-120hp
Dhadley said:
They should be the same.
Thanks Dhadley (again). I may just put that old evinrude on and get some boating in. At least that old electric shift dinosaur runs....
alden135
What will I have to do to hook up the steering? I had cable steering with the 85hp.
Dhadley
Oops! Well, are we looking at push-pull type cable or hydraulic?
Dhadley
Is that what you want to stick with?
alden135
No, I would like to hook up the existing steering from the 1990 POS 120 to the 85.
jimmbo
You're going to have to find some hardware to secure the streering cable to the boat. OMC didn't have provision to use the tilt tube for the cable mount until 1973
Dhadley
I'm a little confused. We're putting an older 85 where the V4 looper was, correct?
What kind of steering is in the boat now?
alden135
The boat has the 1990 steering. 1 cable moves the engine back and forth.
rickdb1boat
Wow. I'm lost! So the steering you have now went through the tilt tube on the 120??
alden135
Ok let's back up.
I have a 1990 120 johnson on a 1990 Sunbird.
That 120 has made me a lieutenant here at iboats and still falls apart.
I was thinking about taking the crap 120 off, and installing a 1969 evinrude 85hp in it's place. The 85 runs and I'm sick of beaching my boat and tearing it apart.
I just wanted to know if it would work.
Thanks,
Alden
Dhadley
There are some aftermarket companies that make an adaptor so your push / pull cable will work on the 85 that doesn't have the tilt tube (it has a tilt pin). T&R Marine used to make some. Or Teleflex makes a standoff adaptor to allow you to use that cable.
91cajun
Alden
8)8)8)8)8)8)8)8) I know the feeling!
