Bolt size for 6hp flywheel puller?
redart
Anyone tell me the correct sized bolts to buy for inserting into the 3 holes on the flywheel ? 1981 6hp Sea-Horse (I think). Thanks.
raczekp1
Re: Bolt size for 6hp flywheel puller?
its the same size as all in jo/ev engines bolts, diameter is 6.3mm,( i used the same as are holding lower unit to mid section) the lenght you just corect by using washers
Vic.S
They will be an American ( inch) size surely ? 1/4" and UNC (OR UNF ?) thread.
They need to be a high tensile, grade 8, bolt or they are likely to break.
Vic.S
1/4 inch like vic said.
And a coarse thread, 20 tpi ?? That'd be a pitch of 1.27 mm in metric
