bolt size prop
bfan781
Anyone know off the top of there head what size socket I need for the prop bolt. 115hp Mariner 1998? Not in the manual that I can see.
bfan781
Re: bolt size prop
Anyone have any idea? Surprised it doesn't say in the manual but I can't find it. I guess I could use an adjustable but dont want to damage the bolt and need to change the prop.
Texasmark
Re: bolt size prop
Guessing but probably accurate: 1 1/16", 1 1/8 will work. I don't have that yearmodel, had a '89 115 and currently a 2002 90 and all used the same size prop shaft/nut.
HTH
Mark
Alumarine
Re: bolt size prop
An adjustable shouldn't damage the "nut" if it's adjusted properly.
Besides, the "nut" shouldn't be that tight.
