Bombard Aerotec Flooring
BOBBING
hii am a newby -- is the inflatable floor on aerotec same material as the tubes - [pvc]"
southkogs
Started you in a new topic BOBBING. You'll get better responses that way. Welcome aboard.
BOBBING
hi i was wondering what adhesive would suit as some seams are lifting a little bit
alanfox55
I usually use Clifton Urethane Adhesive. It's one part but works as good or better than a two part clue. I get it from NRS who make high quality stuff for white water rafting. They just started carrying a new adhesive called HH66 Vinyl Cement. It's much cheaper than Clifton but if NRS sells it I would trust that it works so I'll be trying it out this season.
