Here is how I do decks ..
Material Schedule :
1 layer of1.5 oz mat strips along the deck seam
1 layer of 1708 strips along the deck seam
1 layer of 1.5 oz over entire deck and seam
Polyester resin
Application :
Pre-cut Everything before you start.
Pre-coat the wood with resin as already mentioned above. * this is step is required * .
Apply resin to the deck seams.. then apply the strips of mat and 1708.
Apply resin to the deck .. put down your 1.5 oz mat on the deck ( this is not one Big piece.. but smaller manageable sizes ) . Resin coat the 1.5 oz mat until its fully saturated.
I use a regular paint roller to apply glass in larger sized areas such as this
Now you want to use epoxy .. that's fine
3 layers of 1.5 oz mat should do on the seams .. then coat your deck until it stops absorbing. ( might be a lot of epoxy depending on what kind of wood you used ).
Good luck and put some pics up for our viewing pleasure
YD.
