minuteman62-64
- Apr 12, 2011
- 1,350
Well, after reading many conflicting posts on this subject my conclusion is that I will bond my aluminum hull to the negative terminal of my battery (however, I will not be using the hull as the ground for the electrical components - each will have a dedicated ground wire). The tipping point was when I read the owner's manual for my 1982 Mariner which recommended, for aluminum hulls "...... bond the negative battery terminal to the hull using a #10 wire."
So, I'm now at the point of deciding exactly how I connect the #10 wire to the hull and what type of wire (Cu or Al) to use. Seems like using the wrong materials would create just the corrosion/electrolysis problem I'm trying to avoid. At some point you have to get from aluminum (hull) to copper (wire to negative battry terminal). However, it doesn't seem like a good idea to connect a copper wire directly to the aluminum hull.
I checked out West Marine in the electrical section and they didn't have anything specifically designed for this purpose.
Any of you aluminum boat owners have any suggestions or examples of how your bonding is done?
As always, appreciate any and all input.
