oldhaven
- Aug 30, 2015
- 578
When running a bonding wire from the fuel filler neck to the tank gauge ground should the filler neck be isolated from the boat by a gasket or insulator? It would seem this added wire suggested by CG for all boats would defeat the attempt to isolate the boats aluminum hull from the battery ground if the filler neck was in contact with the metal hull, causing potential galvanic action..
Also, it must not be a problem to fill a permanent tank while the boat is on a trailer even though the boat is not in contact with the ground. Everyone does it. Automobiles have the same situation and I don't recall seeing warnings about touching the filler nozzle to a metal part before fueling up.
