mr300z87
- Sep 15, 2010
- 701
I was in the process of cleaning up some wiring on my V210 Invader cuddy cabin and I notice a green wiring running from the neg battery terminal to the fuel filler. On closer inspection I found that it went in to the fuel tank compartment where the wire was spliced with a grounding lug but not connect to the tank. My question is should this be attached tank (sending unit mounting screws)? And second I have read that this should be bonded to the engine not the neg battery terminal? I want make sure it is correct and safe. I work in the telcommunicaton wiring field so I know the importance to proper grounding and bonding. Thanks in advance for the advise.
Mike
Mike
